Greetings> Question: Have you changed your fluid lately. I had a similar
problem and it took quite a while to fill the radiator up after replacing it.
Apparently the fill tubes go sideways and can get an air bubble in them so as you
heat the water and let it cool you keep adding anti freeze solution and eventually
all the air will come out. Chuck 78 Eleganza, Lompoc, CA I will look in the
morning for the sending unit part number. My books are in the coach. chuck
> Noone responded to my original inquiry, so I'll try again. My water level
> light glows faintly all the time. Shop manual says it's a module in the dash.
> Does anyone know a part number or parts store source? Also, my house
> batteries no longer charge from the alternator, so I think I need a new
> Isolator diode unit. Does anyone know a part number for a replacement?
> Thanks for the help.
> Darryl Kiehl
> 76 Royale
> Darryl Kiehl
> 76 Royale
