Water Level Indicator -- do it yourself
emerystora
14,608
2
1
Here is an interesting water level sensor gauge which can light LEDs to show water level.
It should be easy to adapt this idea to the GMC water tank.
http://www.instructables.com/id/Water-Level-Indicator-Using-Magnets/
Floats could be made with closed cell poly foam instead of the authors use of a 3D printer.
In the readers comments one person suggests that instead of lighting LEDs it could couple a series of resistors so that a
regular water tank (fuel) gauge could read the water level.
Emery Stora
77 Kingsley
Frederick, CO
A supplier that I use for electronics parts has a float type switch for level indication. I believe it uses a reed switch and also has a thermistor
for temperature indications. You'd have to supply the electronics for the temp reader.
https://www.allelectronics.com/item/flw-1/float-switch-with-integrated-thermistor/1.html
FLOAT SWITCH WITH INTEGRATED THERMISTOR
CAT# FLW-1
$3.50 each
10 or more $3.00 each
GatsbysCruise. \
74GMC260 Former Glacier Model style. \
Located in Waukegan \ Keep those MiniDiscs Spinning \ MY GREYOUND IS FASTER THAN YOUR HONOR ROLL STUDENT \ WindowsXP-Win7-UBUNTU STUDIO
