Water heater acting weird.
LarryW
6,022
744
113
Menomonie, WI.
I have this Atwood 6gal propane water heater that I installed in 2012. I put a timer in series with the 12v power. When I get up the morning I set
the timer to 15min, enough time to heat the water for shaving and breakfast dishes, but will not run all day. Until a year ago worked perfect. Lately,
I set the timer for 15 min, and after 10 minutes the flame shuts off and red light comes on. It will then cycle 3 times trying to restart. It does
restart all three times with flame but only lasts for about 10seconds, and then will not restart. If I shut power off for 10 minutes or so, it will
restart and run for the additional 5 minutes I need to get water to desired temp. I have replaced the igniter when I found that the ground had broken
off and worked Ok for about three times out, then went back to shutting down after 10 minutes. Any ideas? TIA
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Larry,
There is a sensor on the back side of the tank that senses the temp.
See if you can fool it and see if it will stay on lot longer.
> perfect. Lately,
> broken
> Larry
> Menomonie, WI.
Jim Kanomata ASE
http://www.gmcrvparts.com
Larry,
Does it not have a thermocouple that confirms there is actually a flame? It that were bad it would shut the gas off as you describe.
Do your cooktop & furnace behave normally? I would think another possibility is low gas pressure.
Douglas & Virginia Smith,
dsmithy18 at gmail,
Lincoln Nebraska,
’73 “Sequoia” since ‘95: "Wanabizo";
Quadrabag/6 wheel disks/3:70 final/Paterson QuadraJet/Thorley’s/Alloy wheels/Sundry other
> Larry,
Thanks for the suggestions, but new thermocouple but will try fooling it, and cooktop is working as expected. Havn't used the furnace in years now.
Larry
Menomonie, WI.
