Water and Holding Tank levels
thomas g. warner
1,863
I believe that the new ones Cinnabar has are made like that.
>I have to replace my float senders in the holding tank and in the water tank
>again. They are costly and do not last very long. It seems that a simple
>circuit could be made by attaching a couple of metal plates to the sides of
>the tank and measuring the height by means of inductance or capacitance and
>eliminate the internal tank floats and variable resistor. Any suggestions?
>Emery Stora
>77 Kingsley
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Another thing that is not needed. When you run out of water you should dump.
Right! All these neat gadgets that break, leak and keep you busy like at home.
Chuck
> >Emery Stora
> >77 Kingsley
> Tom & Marg Warner
> Vernon Center NY
> 1976 palmbeach
How do the new Cinnebar sensors attach to the tanks? Do they uses
same, stock readout gauges:
Herm
should dump.
like at home.
> Chuck
water tank
a simple
the sides of
capacitance and
suggestions?
> > >Emery Stora
> > >77 Kingsley
> > Tom & Marg Warner
> > Vernon Center NY
> > 1976 palmbeach
DO YOU YAHOO!?
My understanding from talking to them is that they replace the originals and
work with the same inside gauges.
>Herm
>should dump.
>like at home.
>> Chuck
>water tank
>a simple
>the sides of
>capacitance and
>suggestions?
>> > >Emery Stora
>> > >77 Kingsley
>> > Tom & Marg Warner
>> > Vernon Center NY
>> > 1976 palmbeach
>DO YOU YAHOO!?
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
I recently talked with Jim Bounds & he suggested that I contact Golby.
I just installed their new holding tank gauge. All of the important
parts are outside the tank & not constantly submerged. The design seems
much improved. I don't have enough time, but my original unit was very
poor. I replaced it with another "OEM" gauge that also failed very
quickly. Give Golby a call and talk to them about the design. BTW the
cost was about $80 and no modifications.
Eric Tipton
etipton
-----Original Message-----
Sent: Saturday, October 31, 1998 4:02 PM
To: gmcmotorhome
Subject: GMC: Water and Holding Tank levels
seems that a simple
or capacitance and
Emery Stora
77 Kingsley
