I guess that puts us back to blind brand loyalty, Ford vs Chev vs Chrysler,
etc. We can't cut them open, that's for sure.
On Fri, Feb 1, 2019, 7:56 PM Emery Stora via Gmclist <
> BUT, how do you know “all other factors being equal” just by weighing the
> battery?You can’t see inside the case unless you cut it open.
> Emery Stora
> > I said "All other factors being equal" which would include factors like
> you
> > mentioned. I was thinking about internal tie straps, vibration
> protection,
> > antimony alloy, electrolyte storage above the plates, insulation types,
> and
> > quality of construction like you mentioned, there are probably several
> > others. We recently lost one MAJOR player in the game, Die Hard by Sears.
> > That one will come back around and bite all of us in the butt.
> > Jim Hupy
> > On Fri, Feb 1, 2019, 7:32 PM Emery Stora via Gmclist <
> >> Sorry, James, but that is not necessary true. Years back I was touring
> >> Atlas Laboratories in New Jersey which was the testing lab for all
> Standard
> >> Oil companies. In their battery testing area they showed some cutaways
> of
> >> various batteries. They tested theirs against other brands. A couple of
> >> them had a 1” thick slab of lead lying inside the bottom of the case not
> >> connected to anything. They told me the sole purpose was to make the
> >> battery heavier. Their testing showed it was actually inferior to the
> >> others but since many people feel that a heavier battery was better, it
> was
> >> a cheap way to add weight. So much for “the heavier the better “.
> >> Emery Stora
> >> 77 Kingsley
> >> Frederick, CO
> >>> When I went to GM TRAINING, this is what they told us. We, Corporate
> >>> GENERAL MOTORS, of course would prefer that you replace GENUINE GM
> DELCO
> >>> with GENUINE GM DELCO. That being said, batteries are sold by the
> pound.
> >>> All factors of construction being equal, the heaviest battery is the
> best
> >>> battery. So when you pick up a T-105 Trojan and it is 15 pounds heavier
> >>> than a Delco, it is 15 pounds better, too.
> >>> Jim Hupy
> >>> On Fri, Feb 1, 2019, 6:45 PM John R. Lebetski >>>
> >>>> FWIW our Delco rep told use there is no less quality in their shorter
> >>>> warranty batteries than the full 72 month ones, just less CCA. They
> are
> >>>> betting
> >>>> with the higher CCA ones you won't need a warranty claim.
> >>>> John Lebetski
> >>>> Woodstock, IL
> >>>> 77 Eleganza II
> >>>> _______________________________________________
> >>>> GMCnet mailing list
> >>>> Unsubscribe or Change List Options:
> >>> GMCnet mailing list
> >> GMCnet mailing list
