Warner Bearing Puller
ray
45
The first time I used the Warner Bearing Puller I found it difficult;
but then who needs to read the directions, right. Well, the second time
I listened to what Tom Warner was saying and it worked great. I
definitely consider this a must tool for the road.
Ray & Elisa
1973 Painted Desert
Corning, CA
The last time I had the bearings done, I gave my very experienced highly
qualified (and expensive) mechanic your tools, the OTC927 and a copy of the
instructions from Cinnabar's news letter and he still had to improvise.
Hopefully, next time I can give whoever does it a clearer instruction to go
along with those beauytiful tools.
I, for one, will eagerly await your instruction.
TIA, Dave
>Ray sometime in the very near future I will write up a procedure for
>removing and reinstalling the front wheel bearings on the GMC motorhome,
>including pictures of the areas I feel are important and critical. The
>procedure will be written with a couple of goals and caveats.
>1. I believe if you properly service the front wheel bearings using the
>procedure I will outline, you will never have a bearing failure. Contrary to
>popular belief the front wheel knuckles, hubs and bearings are not weak and
>overloaded in this application. They have simply been abused by either no
>or improper maintenance., or improper lubrication.
>2. The procedure must be able to be used on the road using the tools
>carried in the coach since the bearing puller was designed with that purpose
>in mind. We have owners travelling all over the continental US and Canada
>and they need the peace of mind of knowing they can pull the rotors in case
>of brake problems or repair the bearings if the need arises.
>3. The procedure can be understood used in any GMC repair shop or by any
>mechanic using regular tools they have, giving them the procedures and the
>wheel bearing tool.
>4. The procedure must be simple enough and explained clearly enough that
>the average GMC owner with tools can accomplish it.
>5. The complete front wheel bearing tool kit must be compact and easily
>transported in the motorhome, whether the OTC927 or hydraulic version is used.
>tom
Thanks Tom
Will look forward to your writeup. Speaking for us we need all the help we
can get.
Marlene
To:
Sent: Tuesday, July 04, 2000 1:56 PM
Subject: Re: GMC: Warner Bearing Puller
to
and
purpose
case
> wheel bearing tool.
used.
> tom
> >Ray & Elisa
> >1973 Painted Desert
> >Corning, CA
> I gave my very experienced highly qualified (and expensive)
>mechanic your tools, the OTC927 and a copy of the instructions from
Dave - I sure hope that he wasn't the same mechanic that hooked up
your rear battery with the wrong polarity! :) :) :)
Emery
>Emery
Definitely not, but good memory, Emery. (sorry, couldn't resist)
Dave (advisor/navigator) & Dege (ALL else), '76 Royale, Santa Barbara, CA
I would love a clear concise version of such instructions.
Tony Bad
To:
Sent: Tuesday, July 04, 2000 4:56 PM
to
and
purpose
case
> wheel bearing tool.
used.
> tom
> >Ray & Elisa
> >1973 Painted Desert
> >Corning, CA
Tom I am a great believer in reading all information to do any procedure. I
find even though it sometimes takes extra time to do this in the long run it
will save time.
Please include a list of all necessary tools as some may not be in our tool
box as yet.
Marlene
To:
Sent: Tuesday, July 04, 2000 6:43 PM
> Marlene the removal and installation of the front wheel bearings is really
> very simple if you read the cinnabar procedure carefully when you are
> looking at your knuckles and hub before and after you remove them. In
> addition make sure you have a nice clean work area. I would degrease
> everything before taking it apart.
> I can assure you that the removal and installation of the front bearings
is
> not difficult once you have a couple of very important points explained to
> you. I noted that someone here gave their experienced (his term) mechanic
my
> tool and he had a tough time removing the installing the bearing. What was
> not clear was exactly what he had trouble with. I can tell everyone in no
> uncertain terms that I would run not walk from this mechanic and would not
> let him put a hand on my coach. While a good mechanic may not have the
> proper tools to remove and reinstall the bearings, the rest of the
procedure
> is routine for any experienced mechanic.
> I think we can write the procedure clear enough and illustrate the
important
> points with picture so that everyone can understand and complete the
> procedure. That is if you are willing to read it BEFORE you start the job.
> For those doing the wheel bearing procedure before I complete the writing
> two words of caution. When you assemble the warner puller to the bearing
> make sure that the seal and retainer is pushed all the way down BEFORE
> installing the puller over the bearing. In addition when installing the
> OTC927 to the split rings do it after installing the split rings to the
> bearing. Make sure that the OTC927 is installed in the exact center of
the
> bearing shell. If you do not than it will take an excessive amount of
torque
> to remove the bearing. If you start the pull and it is really tough to
move
> it, than loosen everything up and make sure it is centered. And one last
> thing. Make sure everything is lubricated including the part that rotates
on
> the small insert to the hub. You do not need large wrenches on both parts
of
> the OTC927 since the lower nut will wedge against one of the long bolts
when
> the top threaded rod is turned.
> tom
> >Thanks Tom
we
> >can get.
> > Marlene
> >From: tom warner
> >To:
motorhome,
the
Contrary
> >to
> >and
no
> >purpose
Canada
> >case
any
the
> >> wheel bearing tool.
that
is
> >used.
> >> tom
time
> >> >Ray & Elisa
> >> >1973 Painted Desert
> >> >Corning, CA
