Wallace Hubs
Apr 8, 1998
32
My coach came with Wallace Hubs or so I was told and I removed the front
tires and the metal center dust cap looking for the grease fitting that the
Wallace Hubs is suppose to have, only found the axle nut. My question is do
I really have Wallace Hubs or not and if I do where is the grease fitting
located.
Thanks
Dave Melton
1975 GMC
26' Palm Beach
Espanola N.M.
Dave:
The grease fitting is not visible from the dust cap you removed. It is
located on the exterior side of the hub (i. e. parallel to the axle shaft).
Jack up the front of the coach and either remove the wheel and look on the
side of the hub for the fitting or crawl under and look for it behind the
wheel and tire.
Paul Bartz
Sent: Monday, June 07, 1999 10:09 AM
Subject: GMC: Wallace Hubs
located.
Look on the hub itself, i.e. look on the inside from the front and use a
flashlight and you might find a grease fitting there. I don't have the
Wallace but have the grease fitting there when I had bearings done
initially.
If that ain't so, someone with Wallace's please jump in.
Heinz
- -----Original Message-----
To: gmcmotorhome
Date: Monday, June 07, 1999 6:08 AM
>located.
>Thanks
>Dave Melton
>1975 GMC
>26' Palm Beach
>Espanola N.M.
Thanks Heinz, I'll look tonight.
Dave
>initially.
>Heinz
>From: DAVE M., CST-7, 5-4682
>To: gmcmotorhome
>>located.
>>Thanks
>>Dave Melton
>>1975 GMC
>>26' Palm Beach
>>Espanola N.M.
Dav,
The grease fitting is on the inner side of the hub.
Sam
located.
Thanks
Dave Melton
1975 GMC
26' Palm Beach
Espanola N.M.
