On my 77-78 house wiring diagram it shows the water pump, porch light, floor lights, monitor gauges and the door galley light as being on fuse #3 with
a #12 purple wire coming off the fuse panel.
It shows the fridge, hall and LPG compartment lamps being fuse #4 with a #12 white wire coming off the fuse panel.
The fuse clips are held to the main power bus-bar by rivets. They are know to loosen and lose connection when power is drawn... in other-words you can
remove the fuse and see power at the fuse clip, but when you install the fuse and current is drawn, the power is lost across the rivet connection.
Use your voltmeter or test light to look for power at the input to the fuse and the output side of the fuse. Each point where there is a connection
could be faulty. Also I have seen in my 45 years of mobile electronics experience where the fuse itself can be internally faulty but the link does
not show as "blown".
You say you see power at that pump, but the pump does not run. There is a pressure switch at the pump which could be faulty. There is also an inline
fuse at the pump witch could be faulty or its connection is faulty.
As for laps working with the fuse removed, I can see that happening with the Galley lamp. It is fed directly from fuse 1 and also from the galley
door switch on fuse 3.
I have replaced my glass fuse panel with an ATO fuse panel because the connections in the OEM glass panel were intermittent.
Bruce Hislop
ON Canada
