Voodoo/no pan gasket
dave1
460
>... How are you goint to seal the pan to the tranny
>if you do not use a gasket?
I never use gaskets for transmission pans, even in cars that keep the=20
gasketed area soaked full time in fluid. I never have problems with leaks.=
=20
My experiance is that modern sealers work much better than the cheap cork=20
gaskets that come with most trans filter kits. Skipping the gasket makes=20
the pan and trans much easier to clean up the next time I have to remove=20
the pan.
>And when taken in to consideration the small
>conductive area of the flange is insignificant when compared to the volume
>of the tranny fluid which is the main coolant.
I agree that there is probably not much to gain regarding heat dissipation.=
=20
I just skip the gasket because its easier to install and it seals better.
Dave
Ann Arbor, MI.
73 Sequoia (26'/455/HEI/TBI/160=B0/3.42)
