Just an update.. and a question:
First, the distributor cleaning and lubricating seemed to go pretty well.
Replaced the rotor and cleaned up the plugs while we were at it.
Wouldn’t start at first, so timing had to be set from scratch via directions from Miguel MGM,
and with the help of an experienced mechanic friend, going off cylinder #1, manually turning the engine…
setting timing… voila! Took it for a 40 mile test drive today, seemed to perform just fine, didn’t hear any ping.
But when i stopped at a gas station and went to start it again
with a hot engine, it turned over ‘slowly’, as if it was a low battery, but i know the battery and connections are solid.
(replaced starter, battery cables and ignition switch 10 days ago)
So, i remember once hearing something about how bad timing can cause difficulty starting... with a hot engine?
The engine starts up just fine when its cold. but after a hot drive, it turns slowly.
So do i need to advance or retard the timing slightly?
Thanks for the ongoing education, GMC mechanic friends!
cheers
Greg / SolarSonic / Los Angeles
> i was experiencing a very high idle when coming to a stop at traffic lights.
> consulted with Miguel at MGM GMC who told me to take a look at the distributor, and see if the weights
> are snapping back, or if they?re frozen up with rust, etc.
> Well, the little ?weights? on top seem to move just fine, but lo and behold, the part just underneath it
> (centrifuge advance?) feels really gummy, and needs to be manually moved back by hand.
cheers
