If you look at this article about the primer switch,
http://www.california.com/~eagle/onan.htm
you will see pictures that show the connection to the hour meter from the
start switch. If you run the Onan and look for the line that has 12 volts
on it while running,(just like for the primer switch) you can use this
connection to attach the hour meter. At the same time, you can install the
primer switch ;>)
gene
>I am battery .000 so far. The roof vent over the refridgerator only shows
fins and no vent tube access to clean out the rust. From the access
compartment looking up the tube, it ends below the vents and wouldn't let
anything be pulled out of it anyway. Am just looking for a way to clean
out the rust.
>Next concerns the Onan hour meter I would like to install. Can't find any
extra wires by the remote panel or starter so will want to install it back
by the Onan itself. Anyone know where to hook it up back there?
>Emory, don't you bother to respond, you have much bigger problems than I
do (vapor lock). Thanks to whoever responds. Franz Staugler
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
primer switch ;>)
gene
out the rust.
mr.erf
