Here's an update on the valve tick /squirting lifter on my 455
Jim,
it looks like you are right on the bogus lifters. I pulled #1 out and found a broken flow restrictor?
A piece was lodged in the check valve holding it open
Here is the disassembled lifter, a 'good lifter is shown below it.
"]http://www.gmcmhphotos.com/photos/data/7358/medium/Broken.jpg]
[/url][/url]
now, about that good lifter, when out of the vehicle, on the workbench, I tried to push the plunger down, it does not move. Not even a little with my full weight on it for a solid minute, no oil came out of the hole on the side. not even a drip. I repeated this on 3 other lifters. I was on the phone with Matt Colie and he tells me thats not right ( as I suspected! )
But they look OK otherwise
Other news, Rocker #7, the coked up one, is worn on the pivot.
So I think it's new lifters and rockers at least
Compression looks ok, 195+- across the board except #2 which is about 180-185
Keith Vasilakes
Mounds View MN
76 exRoyale
MicroLevelhttp://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf
Jim,
Keith Vasilakes
Mounds View MN
76 exRoyale
