> I agree the howell is a better system, but just for the record the fitech also allows distributor control, just with a smaller matrix. It allows
> the use of a modern msd distributor. Mine is setup that way.
> Not arguing, just posting so that if someone else reads they know that fitech also does control timing if you set it up that way.
Justin,
I have just been perusing the Fitech documentation and looking at the timing profile. It does not mention a knock sensor input.
Did I miss something or do they not make timing corrections?
Justin,
