Value added for the Howell/GM EFI
> I agree the howell is a better system, but just for the record the fitech also allows distributor control, just with a smaller matrix. It allows
> the use of a modern msd distributor. Mine is setup that way.
> Not arguing, just posting so that if someone else reads they know that fitech also does control timing if you set it up that way.
Justin,
I have just been perusing the Fitech documentation and looking at the timing profile. It does not mention a knock sensor input.
Did I miss something or do they not make timing corrections?
Matt,
You didn't miss anything, there is no knock sensor with the fitech.
I've read a lot of discussion on the subject and the general consensus seems to be that knock sensors really don't work well unless they were
engineered into the engine to begin with ( I'm quite certain you're more knowledgeable than me in this area!)
The Fitech uses a simple 3x3 matrix for the timing, and is not intended to be used for lean cruise like the EBL.
It's simply an upgrade to a worn out distributor and is easily adjustable.
I based my timing numbers on Dick Patterson's graphs for his dizzys.
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
Justin,
Your correct about the pro and con of the knock sensor.
I still have a old MSD Knock sensor I use on my Cad 540 .
Depending on location and different part #, I have been coached by couple
people.
I do believe in the theory that you cannot always hear preignition.
Hopefully I will get some people to test location and part # for use on the
403/ 455.
> Matt,
> Justin Brady
> 1976 Palm Beach 455
http://www.appliedgmc.com
