"I am sorry Gary but I do not agree with you. No TEST can be valid unless=
you
know ALL of the factors in the equation BEFORE you change something. If o=
ne
or more factors change at the same time, how do you know which one caused=
the change? If you do not know what the ride height, caster, camber and
torsion bar preloading, tire pressure etc. is, than you can never know wh=
at
caused the change."
Tom while I agree that it is more correct to start with a coach aligned t=
o
factory spec's the test is still valid.
Changing the ride height only changes the camber.
Regards
Gary Zingle
1973 GMC 26 foot
you
ne
at
caused the change."
o
Regards
Gary Zingle
1973 GMC 26 foot
