Yikes-- I am not at home with my spare pump just now. I will have to get
back to you in a week. I am sorry -- I will put your note up on the net
and someone there can answer faster. Sorry for the confusion.
gene
Hi - read your excellent article on installation of AC pump. A question?
You refer to electrical connections on the pump body as "left to right" -
if the pump is mounted correctly, the connector receptacle is vertical! If
I can't find the original connector, is the 1st (12 v.+) the top (nearest
the mounting ear) or bottom hole? Thanks!
Jeff Diamond
gene
Jeff Diamond
