source numbers for filters
http://www.california.com/~eagle/addens.htm
gene
>Em I just bought a new pump but am unable to find a new filter. Where did
>you get yours?
>tom
>>>Emery
>>>I have been reading all of this about the filter. I got my vacuum
>>>pump from Leigh. There is no filter with it. Mine seems to be a little
>>>different. The instructions with it said to hook the line from the engine
>>>to the pump, then hook the brake booster to the other outlet on the
>>>pump. It sure seems to work well enough. What am I missing?
>>>Take Care
>>>Arch
>>Arch - it will work fine without the filter. The air flow is
>>normally from the pump to the engine but there is a potential risk
>>that contaminants from the engine (carbon deposits, grit) could get
>>to the pump. The pump is a diaphragm pump and if deposits get under
>>the diaphragm flapper is could cause leaks and faulty operation. The
>>filter is just an added insurance to prevent this possibility. You
>>can see a picture of it on Gene Fisher's site on the pictures of the
>>vacuum pump.
>>If you send me your address I'll put one in the mail for you.
>>Emery Stora
>>77 Kingsley
>>Santa Fe, NM
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
