>Hey Folks;
> I don't know if this is useful but this is the bracket I made to mount my
>Vac Pump. I got this pump off a 1985 Celebrity. Here is the site with the
>drawing, look under GMC Stuff.
>http://albums.photopoint.com/j/ViewPhoto?u=896604&a=6526780&p=24491159
> I have no idea if it will fit other pumps or years. The bracket mounts to 3
>square holes in the panel under the brake pedal. If you don't have the holes
>this won't work. I used 1.5" long, 5/16-18 Carriage bolts, and Nylock nuts,
>the square holes fit them perfectly.
>Best of luck
>Mark A
Mark - really not even necessary to fashion a bracket. You can
easily hang it from the existing bracket behind the driver's side
front door. The pump is supposed to hang with the drip hole down so
that any water or condensation will drip out and not stay in the pump
to corrode it. You can see my mounting place on my photopoint site
http://albums.photopoint.com/j/AlbumList?u=209754
You just drill three holes into the bottom of the bracket. I believe
that I used a longer bolt on the front hole with some washers as
spacers to hand the pump level. It helps to drill one hole and mount
the pump and then mark the other two holes, remove the pump and then
drill the other two holes. Drilling them slightly overside for the
bolt will make it easier to line things up.
Santa Fe, NM
>Best of luck
>Mark A
Santa Fe, NM
