John,
The rule of thumb on the cost of purchasing a coach has been pretty
accurate. I have done several and that is what to total cost has worked
out to and just a little more depending on how much you do.
If you are running the stock hubs then every 24K miles is a good starting
point. If you have the hubs with the grease fittings installed then you
grease them about once a year and the bearings has been shown to have very
good bearing life. Some have shown 100k miles and still look good. The
use of a synthetic grease for the bearings is a major upgrade choice.
I have run a synthetic oil, since the early 2000's and presently use Mobil
One 20-50 and change it about every 5500 miles maybe a little. I recently
have been just changing the oil filter about every 3K miles as the oil
doesn't degrade in 3K miles. You going to ask why a 20/50 weight and that
is because our engines work very hard pulling 12K pounds down the roads.
When I ran the dino oil it was one a year in the fall to get out the junk
and acids and plus a filter and that was right around 3K miles at I did not
use the coach during the winter. I now use the coach mostly years round as
I spend the winters in the Southwest.
J.R. Wright
GMC Great Laker
GMC Eastern States
GMCMHI
TZE Zone Restorations
78 Buskirk Custom 30' Stretch
75 Avion (Under going Frame up Restoration)
On Mon, May 7, 2018 at 2:34 AM, John Phillips
wrote:
> So if I get a deal on a $5,000 coach I should expect to put another $25,000
> with it.
> Is there a recommended spare parts list?
> Do we really have to repack the front wheel bearings every 3,000 miles?
> That is like each oil change.
> > > Hi, new member and potential buyer here. I am curious how often you GMC
> > owners use your rigs.
> > > Are any of you full time RVers? If so how many years have you been on
> > the road? How many miles per year? How many breakdowns? How difficult
> was it
> > > to find parts and service on the road?
> > > Are you a part time RVer? If so how often do you take trips and how
> many
> > miles per year? How many breakdowns? How difficult was it to find parts
> > > I am actually thinking about going full time for a couple of years. But
> > I am concerned that with any classic RV that it may not be the best idea
> > > if there are a bunch of breakdowns?
> > > I am open to your advice and or suggestions.
> > > Thanks, Al
> > Al,
> > You have a lot of good advice here, but I shall add a little more. If
> you
> > are not an effective mechanical technician, then a GMC may be a bad
> choice.
> > As mentioned above, you should seriously consider your options. Mary and
> > I can live in out coach for a month at a time with little difficulty,
> but we
> > have been sharing space for lot of years and the coach is not the
> smallest
> > of them. Renting something might be a good start.
> > While they are not difficult to maintain or make small repairs, the
> > majority of today's automotive technicians do not know how to do
> > diagnosis. They
> > read the code off the OBD and change parts. When most shops see a GMC,
> > the run for cover. Changing parts are what they are good at, and if that
> > does
> > not solve your problem they will still do the other thing that they are
> > good at which is writing a bill.
> > There are about a dozen good shops scattered across the country and
> > several that can supply any needed parts. Getting the correct part from
> a
> > store
> > front parts store is not always easy as the catalogs are not always good.
> > As you read here, be aware that this is a group of a couple thousand or
> > more and many of us use the the coach a lot. So, you will read lots of
> how
> > to
> > deal with issues here. If you read those, you may get the impression
> that
> > these old girls are unreliable. Remember that you are looking at the
> > sample of several thousand and then it will come into focus.
> > If you are any kind of a passable wrench, there is nothing about a GMC
> > that will stop you. The technology is late iron age, and the service
> > documentation is all available. There are very few special tools that
> can
> > be required for normal maintenance. You have to get into your brain that
> > the normal maintenance is much higher than would be for a modern vehicle.
> > That maintenance is essential for reliability. One of out members
> > described the situation as you have a 40 year old truck (it isn't a
> truck,
> > but let that slide) carrying a 40 year old house that has been through a
> 40
> > year long earthquake. Of course things will need repair.
> > We have put just a little less than 70k on our coach and it has been on a
> > hook once. Some years back, we did 11kMi of excursions and we broke a
> > drawer slide in Yellowstone. With the stuff we had on board, I was able
> > to make a satisfactory repair in a day. The only heavy spare I carry is
> a
> > starter. (If that goes out, there is no work around.)
> > We would be glad to have you as part of our group, we want you to come in
> > with your eyes wide open. These may be old coaches and that are really
> > neat, but they are not for those that are not ready to deal with the
> > issues. We have a saying here, "A reliable and ready to travel coach
> will
> > cost
> > you 30k$, all at once or as a kit." The "kit" part means that sweat is
> > include at shop value. I don't believe you will hear anybody that
> disagrees
> > with this.
> > Keep us in mind.
> > Matt
> > Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> > Electronically Controlled Quiet Engine Cooling Fan
> > OE Rear Drum Brakes with Applied Control Arms
> > SE Michigan - Twixt A2 and Detroit
> *John Phillips*
