Thanks to all for your suggestions. They were all greatly appreciated. I have checked all my battery connections, and everything looks good.
Both my batteries have been checked by two different battery stores, and they say the batteries are good.
I have just noticed that when I put my key into the ignition, and depress it slightly, I get a buzz from the battery isolator. Is this normal?
Over the last few days the coach has gone from starting when cold, to barely starting at all, to now not starting at all.
I checked and I do have voltage (12.5) going down the starter.
At the moment I am only getting a click when I turn the key to start the engine. Batteries are still showing 12.5 volts when I check the battery with the volt meter.
> Haven’t posted in a while, but I have one that has me stumped, and could use some advice..
> My engine starts when cold. When the engine is warm and I turn the engine off and then try to restart it, it acts like the battery is nearly dead. I’ve had the batteries checked at two locations and both say the batteries are good. Once the engine is completely cold, the coach starts just fine.
> I recently had both the alternator and starter replaced thinking they were part of the problem (they need replacing anyway) but that did not solve the problem.
> After stopping with the engine not running I get a 12 volt reading from the battery, and while the engine is running I get a14.5 reading at the battery, so it appears that the batteries are charging while the engine is running
> Coach runs fine until I stop, then it barely cranks over, until it is cold again several hours later.
> thanking everyone in advance for your thoughts.
> David Gardner
> 1976 Birchaven (455 motor)
> Oxnard Ca
> David Gardner
> Oxnard Ca
