Under Dash Instrument Panel
bartz paul
1,225
Gene:
In looking at subject pictures on your web site, I see you've used a piano
hinge, which I like, to secure the bottom of the panel. To the right of the
steering column, on the bottom of the instrument panel, there is a small
channel in which you fit the tab of the under dash panel into. That
requires an upward movement to fit it into place.
I'm assuming you eliminated that feature with your hinge arrangement?? If
not, please explain how you accomplished.
Paul Bartz
