> 1. Timing: It seems that this is a two person job. It
> appears that the timing mark is only accessible by laying
> on your back? I guess you could do a trial and error
> adjustment then check routine. Any suggestions?
I'm confused(not a new experience) - while my timing marks are difficult
to see, I definitely didn't need to lay on my back. I chalked both the
harmonic balancer and timing scale, laid my "bridge" boards across the
driver's side of the engine compartment and was able to shine my timing
light through a narrow slot between the belts and hoses.
> 3. (Yes, I know, there are Three Things posted) Distributor
> re-plumbing. Just wanted to confirm that in taking the
> vacuum advance to a vacuum source at the base of the carb,
> disconnection in NOT required to do the timing adjustment.
Still confused - my understanding is that you're setting the "initial"
advance and you don't want any vacuum at this point. I disconnect and plug
the distributor vacuum line.
That's what I do,
Patrick
That's what I do,
Patrick
