Two Airbag, or Not to Airbag?
blur911sc
140
So my new-to-me coach has one new-looking airbag, somehow mounted using the plastic cones even though it seems to have spare metal ones in a box of
spares. The airbag on the driver's side is kind of scary looking, very old and cracked, I don't trust it to go anywhere and it needs to be dealt
with. The system will leak down if left over a day or so.
I'd love to go all out and get a quad bag system, but I need to keep the budget under control in case more things come up, as I'm sure they will
before I take if for it's safety inspection. I still have to figure out the brakes and CV boots and deal with the broken wheel stud, at the very
least.
So, do I get one new OE style airbag and maybe cones for the other side? Anybody have one good used OE bag for sale?
Or, should I get a newer system, (I'm slightly leaning towards Daytona Ferrera system) for both sides?
Is it more economical to just get the end-plates shipped and buy the bags locally in Canada? Does anyone do this or is it cheaper/easier to just
order everything and have it shipped from the US?
Burl Vibert
Kingston, Ontario
1976 GMC 26 foot, don't know the model
check with Frank Borman in Bluevale Ont he has a bag system that he made 519 325 6263 I don't know if he sells it but he showed me a set on a coach
when I was there
There are good used bags and aluminum cones around from people changing them out for non OEM bag systems. I’d replace the plastic and get one good
bag so you can concentrate on all the other issues.
John Lebetski
Woodstock, IL
> good bag so you can concentrate on all the other issues.
That would certainly be the most economical option for now. I'd like to put off upgrades until I know what else we'll need.
So, does anyone have a bag and cones to sell me? I guess I should put an ad on the Swap Meet list/forum too.
Burl Vibert
Kingston, Ontario
BTW, thought I'd mention I've probably changed more blown airbags than anyone on here.
Where I worked we had a ASRS, Automated Storage and Retrieval System, it stacked 5000lb skids in 8 levels high and 35 long, we had three of them that
I worked on.
The skids were lifted off the conveyors for the "stacker" to pick up by inflating airbags very much like the ones on our GMCs. They had to lift up
about a foot to clear the forks.
Well, quite often they would blow, you could hear if from the cafeteria, I've been next to them when they blew, loud to put it mildly.
Interestingly, I'd never changed the design that looks like the ones on the quad bag or Ferrera system, we used them at one end where they only had to
lift 6 inches and they never blew.
https://postimg.cc/tn5Zgytf
In this picture you can see the lift tables near the bottom, one on the right has a skid of rubber on it, the left one is lifted by a pneumatic
cylinder as we got tired of changing airbags and eventually modified them to use 14" diameter cylinders.
https://postimg.cc/9D30jDhM
I don't miss working on that thing, it was dangerous. Had to climb it too many times.
Burl Vibert
Kingston, Ontario
1976 GMC 26 foot, Sheridan reno, don't know original model
