The Sony might have a minimum allowable input voltage. If the voltage drops below
that point the unit will not function. One way to ascertain this is to use a
variable 12v power supply & lower the voltage to see if the Sony cuts off.
Batteries:
The best way is to use an ammeter in series with the converter & batteries. The
nasty way is to use a battery hydrometer. You can also measure the battery
terminal voltage with the converter turned on. Battery voltage should be approx.
13.6v to 14.2v. Turn the converter off & turn on a few 12v lights for a few
minutes. This will dissipate the surface charge. Battery voltage should be approx.
12.6v. However, a defective battery can still show good terminal voltage & not
sustain a good charge.
The Coast Guard will not accept battery voltage monitors as an indication of
battery charge for this reason.
> I have two things that concern me.
> 1. A 8" AC/DC Sony that plays fine when on AC. And it only comes ON sometimes
> when on DC. It is hooked up to a Winegard Antenna on the roof.
> 2. I have 2 Interstate batteries (deep cycle) hooked up in parallel. I really
> can't tell if and when they are charging. I leave GMC hooked to a 20 AMP
> source most of the time. I believe that they are charging slowly with the
> Generator running and when the GMC engine is running. Anyway to tell for sure?
> Thanks,
> Gene '77 PB
Batteries:
> Thanks,
> Gene '77 PB
