What happens lot ofthe time is that the socket that is stamped inti the
metal housing looses contact at that point.
We sometimes solder a bridge there.
> I did not mean to say that these are the only possible causes but are a
> good place to start looking.
> Emery
> > There are three possible causes.
> > 1 . corroded or loose contacts on bulbs. Remove bulbs one at a time and
> clean them and spray in some contact cleaner.
> > 2. A broken filament inside a bulb that might be dangling and shorting
> out.
> > You can check 2 as you are checking 1.
> > 3. A bad ground. Likely the one in the rear on the inside wall beneath
> the area of the license plate. That ground is a cluster with about six or
> eight wires attached. The license plate holder often leaks water to the
> inside which runs down and rusts the ground cluster. There is a similar
> ground in the front inside corner by the driver but that is less likely to
> be the problem
> > Check all turn signal bulbs including the ones on the side.
> > Emery Stora
> > 77 Kingsley
> > Frederick, CO
> >> Plastic front and rear end caps.
> >> Jim Hupy
> >>> yeah I figured that was probably the case, got an idea where to look
> first?
> >>> 73 Canyon Lands, (a.k.a. The Yellow Submarine) West Los Angeles CA
> >>> _______________________________________________
> >>> GMCnet mailing list
> >>> Unsubscribe or Change List Options:
> >> GMCnet mailing list
http://www.appliedgmc.com
