Emery
I am glad you hit upon this. I called TSM last year and was told not to
remove the residual valve . Have installation procedures changed?
Herm/Tucson
> A question for those of you who have installed the
> TSM kits.
> The instructions say:
> "The residual valve holds ten pounds on a drum brake
> system to keep the
> spring on the shoes from collapsing the wheel
> cylinders. Residual valves can
> be found in the rear line of the dual master
> cylinder or in the rear brake
> outlet of the combination valve. It can be pulled
> out using a sheet metal
> screw."
> Does anyone know where it is located on the GMC?
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
Do You Yahoo!?
Herm/Tucson
> TSM kits.
> system to keep the
> screw."
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
Do You Yahoo!?
