1st thing - does not need to be "upgraded" a good stock coach will not overheat.
but, there are a few things he needs to do...
BAsics - check timing with a timing light. make sure the advance mechanism is working on distributor.
know the thermostat is working. 195 degree in my experience is the one to have. Some say 185, I highly disagree.
know that the fan clutch is good. Some say new fan clutch's are random on how well they work, but I installed a Napa part 2747 fan clutch
this past summer, and i know about 4 others that have as well and so far all are workers.
after that, it seems our 45 year old radiators can be not working as well as it should. myself, and i know others had engines that tended to get a
little warm under load, and a new radiator fixed that problem. mine was pretty gunked up.
dont be trying to drag heavy cars up the mountains either.... a good coach should have no issue with that, but the amount of extra load that creates
is crazy big, and if you have other mechanical issues it will only compound trying to isolate the issue.
if they still have problems after making sure the above is all in perfect order, let us know for further possible issues.
Jon Roche
75 palm beach
St. Cloud, MN
Jon Roche
75 palm beach
St. Cloud, MN
