Just call our office and we can supply as we have all.
just get rougher diameter of it.
On Sun, Sep 29, 2019 at 1:21 PM John Fredrikson via Gmclist <
> > The item is called a "cam follower", and you can determine which one by
> > messing the one you still have. Manny's B-track uses one approximately
> like
> > this:
https://www.mcmaster.com/#3643K13
> > But I'm guessing at dimensions. You'll have to determine those from the
> > other side.
> > Rick "have McMaster app will travel" Denney
> Thanks Rick! That does give me a place to start. I've pulled off the part
> from the other side to measure. The spacer it uses is a about 2" long with
> about 1 3/8" hex with tapped holes on each end. One of the ends is tapped
> off center. That end is bolted to the bogie. The other end has the bearing
> bolted on and fits into the track that is bolted to the frame. The spacer
> looks a bit like this one, though the hex shape is almost the full length on
> mine.
http://www.gmcmhphotos.com/photos/true-track-2/p40227-pict000414.html
> Is this spacer unique to any maker in particular?
> I think I can piece together something to work from the link that Rick
> posted along with other parts from McMaster. Of course it would be easier
> to do
> it with the parts from the manufacturer.
> Thanks!
> John
> John Fredrikson
> Fayetteville, GA
> 1978 Eleganza
http://www.appliedgmc.com
