Trip Report
Carl Stouffer
4,677
361
83
Tucson, Arizona 85718
On June 14, Kathy and I completed a cross country trip from our home in Tucson, AZ to our birthplace in Lebanon, PA. Total mileage was 5246 miles.
We took our time with the longest day being just under 350 miles and the shortest being about 30 miles. On the way, our stops were; Las Cruces NM (at
Hal Kading's place), Monahans Texas, Jacksboro, TX, Arkadelphia, AR, Memphis, TN, La Vergne, TN, Kingsport, TN, Shenandoah NP, Virginia, and finally
just outside of Fredericksburg, PA, where we stayed for three weeks, parked at Kathy's aunt's farm. Several were two night stays.
The most we payed for a space was $54.00 at Graceland RV Campground in Memphis, the least was at Hal's place at the Las Cruces Airport.The rest were
at state parks, Forest Service campgrounds or C.O E Campgrounds ranging from $8.88 - $28.00 per night. The motorhome used a LOT of gas, and only a
pint of oil on that leg of the trip. The only problem I had with it was that the cruise control decided to take a break for about 50 miles somewhere
between Nashville (La Vergne) and Kingsport. It started working again the next morning and never failed again.
We spent 3-1/2 weeks visiting with family (mostly Kathy's and some of my extended family), with a side trip to the Flight 93 Memorial near Shenksville
(a very moving experience, by the way). I changed the oil while we were there. WE left PA on Memorial Day, after a huge family picnic at Kathy's
Aunt Sophie's house and headed up toward State College on Route 322.
First stop of the return trip was at Cook Forest State Park in PA, then on to Canton, then Mansfield, OH, Ft Wayne and Indianapolis, Indiana, (where
we met up with my nephew and his family for dinner), then on to Springfield, IL. two nights, (Land of Lincoln) Then to Hanibal, MO, Topeka and Dodge
City, KS, then to Amarillo, and Palo Duro Canyon, TX, where we camped for two nights, did some hiking, and took in a showing of "Texas The Musical"
(Highly recommended) in the park's amphitheater. Took our time going across New Mexico with stops in Roswell and Deming, then home on June 14.
Overall, the coach performed admirably with the speed averaging between 60 and 65 mph most of the way. The only problem I had was some fuel
starvation on the way up into the Mescalero Mountains at temps of well over 100 degrees, which I'll get into in a separate post when I have a chance.
The weather ranged from crosswinds across NM and TX, to torrential rains in East TX, AK, and TN, to misty rain in Kansas and Texas. Temps ranged from
the low 40s in VA to over 115 in TX, NM, and AZ. The Onan and roof air got a lot of use toward the end of the trip.
We had a great time and I would encourage all of you to take a trip like that if you have the time!
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Oh, we saw only ONE other GMC the entire trip. It was parked in someone's yard along I-69 somewhere in Indiana (I think).
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
> Thanks for your report
You're welcome. With all the problems on these forums, I like to put up a success story once in a while to encourage others to go for it (although
most of these guys do all the time).
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Our cruise control does the same thing...quits working for awhile, then starts working again. Been like that for the 18 years we have owned her.
Doesn't happen too often, though. One of these days I'll make the effort to figure out why.
Nick Chapekis
Ypsilanti, MI
78 Kingsley
This actually came up on the list a couple of months ago. I saved a copy
of Ken's email because I need to check my coach as it exhibits the same
basic problems. Here is a copy of what Ken sent out. Hope it helps you.
> Here is an off the wall problem I have found on a couple of these that won't engage or intermittently drop out after engagement. The CC unit is
> mounted to the body of the coach just behind the hatch cover. The CC unit is powered by the engine 12 volt power system but when they mounted the
> unit it was grounded to the body which is the house 12 volt ground. So the return ground path has to go through couple of jumpers on the back of the
> trans and another from the body to the frame. After 40 years they deteriorate and then there is no return path back to the engine ground.
> The easy way to check and fix this is to disconnect the ground wire on the CC unit. Attach that wire to about a 2 foot new piece of wire. Then
> attach the other end of the new wire to any bolt on the engine just below the CC unit.
Gerard Hickey / WTØF IRLP:3067/Echolink:529661
hickey DMR: 3102272
425-395-4554 Allstar: 531920
We make a trip from central Tx to northern Minnesota every year (1200 miles). Only twice in 25 years have we broke down - once for a transmission n once a blown engine. The GMCs like to run. Keep going as much as u can!
Sent from my iPhone
> This actually came up on the list a couple of months ago. I saved a copy of Ken's email because I need to check my coach as it exhibits the same basic problems. Here is a copy of what Ken sent out. Hope it helps you.
> hickey DMR: 3102272
Sounds like a great trip! If you haven’t already done it, do the southern route to Florida. Lots of interesting sites and things to do. Especially
the beaches in Destin Florida!
Scott.
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater, everything Lenzi. Alex Ferrera
installed MSD Atomic EFI
Houston, Texas
Thanks Scott.
We have been on that route on a bonsai trip in a car when I moved my wife from Ormond Beach to Tucson 22 years ago, but plan to repeat it in the
motorhome at a more leisurely pace.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
We loved that route as well. Pass Christian, MS is the best in my book.
> Thanks Scott.
Thanks for that Gerard. I had previously read Ken's missive about grounding the cruise control transducer to the engine, and had done that several
years ago. Maybe it's time to check that ground again.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
