Trip report
jerry burt
409
First real shake-down trip. 5 days, Fresno - Oakdale - Stanford University Med Center - New Brighton Beach - Big Sur - Cayucos - Casa De Fruita - Home
in Fresno. We stayed in a hospital parking lot, state campground, and private full service RV parks. So we got a taste of the different types of
amenities.
695 miles and the only problems were from the "nut behind the wheel".
Big Sur State Campgrounds are still closed and being used as staging areas for the firefighters. Private RV/camps are open. We saw one area where the
burn reached Hwy1.
I didn't keep track of gas mileage because half the time I had the generator driving the roof air. I know, I should have anyway... next time.
I developed a gas smell and I think it is at the fill area.
The "Hot" water heater was scalding hot from the coolant lines. In fact, the cold water supply was also super heated. Any suggestions for a reason is
appreciated before I start tearing things apart.
There are things to do yet. (Isn't there always) But, we're happy campers.
Patti & Jerry Burt
73 Gmc 26' Canyon Lands -
Photos - http://jburt.smugmug.com/GMC-Motorhome
Lots of upgrades but lots to do to make it ours.
Members: FMCA - GMCMI - GMCWS - Pacific Cruisers
You need the reverse flow valve .
> amenities.
> burn reached Hwy1.
> Patti & Jerry Burt
Applied/GMC, Fremont,CA
For the gas smell, take a look at your filler neck. Does the filler neck
have either RTV or a rubber gasket to prevent overfill gas from seeping
down the outside of the filler tube.
> University
> Home
> of
> > amenities.
> areas
> the
> > burn reached Hwy1.
> time.
> reason is
> campers.
> > Patti & Jerry Burt
> Jim Kanomata
> jimk
> 1-800-752-7502
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
Thanks Jim, I'll pick one up.
Thanks Bruce I'll take a look.
Patti & Jerry Burt
Sounds like a overall successfull trip.
I didn't read anything about engine overheating or excessive heat at the rims. That's good!
Enjoy! Scott
Scott Nutter
1978 455 Royale Center Kitchen, Quad bags.
Houston, Texas
> Enjoy! Scott
Not that I could tell with stock gauges but then the outside temps were pretty mild. (70-80s F) Actual gauges have been moved to the top of the
priority list. Stock gauges just don't cut it. My biggest concern was oil pressure. At times it would drop to the quarter mark at idle but no clicks
or knocks. I'm considering the Digi-panel rather than separate gauges.
Hubs ran 150-160* and all were within 10* of each other.
Patti & Jerry Burt
As far as I'm concerned at idle with a warm engine if you get 1/4 on the gauge that is good. Digi panels are great, I don't think they are made
anymore. If they are, please let me know.
Get an inferred temp gun and hit your rims when you stop for gas. When I hit mine they are usually 30*f warmer than outside air temp.
All in all, sounds like you have a good coach!
Scott Nutter
Houston, Texas
The website is still up but the gmcmotorhome.info, Digi-Panel link and email are bad. http://www.digi-panel.com/ works and he now has a gmail email
address: digidevicesinc @ gmail I sent an email so I'll let you know.
Patti & Jerry Burt
> > made anymore. If they are, please let me know.
> email address: digidevicesinc @ gmail I sent an email so I'll let you know.
Digital Devices is still building, but trying to ramp down. If you want one, you better get in line while they still have boards and parts inventory.
Art may quit any day now.
I wonder if Dinosaur would pick up the design?
==johnny
