Trick to screw fuel line into carb?
There are at least 2 carb inlet filters for the Q-jet. One, long version is
used on the 455. It is a difficult one to start the fuel line threads on
because of the proximity of the thermostat housing.
The second version is shorter, and uses a shorter filter. It has more
clearance to start the threads from the fuel line. I converted my line to
AN-6 braided stainless steel, covered with insul-sleeve. The line is
flexible and much easier to handle.JWID.
Somewhere on the Blue Danube.
On Sep 1, 2017 4:25 AM, "Chris Geils via Gmclist"
wrote:
> If anyone is looking for a replacement pump-to-carb fuel line, Inline tube
> makes a reproduction part for a '73-'76 Olds cutlass that should work;
> https://docs.wixstatic.com/ugd/4d7af2_9dac1b92b352467ab9d76476103e76ce.pdf
> They also make a similar part for '77 cutlass with 403.
> Fortunately our GMCs share a few parts with the desirable classic car
> world.
> One caveat; The plane of the carb flange is angled slightly differently on
> rwd vs fwd Olds engines, due to the position of the engine as installed in
> the vehicle. Rwd Olds v8s, like most rwd v8s, position the engine with
> the crankshaft axis dipping toward the trans and rear axle for alignment,
> while the Toronado has the crankshaft axis more parallel to the ground.
> They designed each intake manifold to place the carb parallel to the ground
> for proper float level orientation. The carb mounting flange tips
> "forward" on a rwd manifold, and relatively "rearward" on Toronado. This
> angularity would make a very slight difference in the fuel line as well,
> but I suspect it could be made to work by tightening the carb last. Inline
> tube also offers a '67 Toronado fuel line that might be closer to our
> original part...for $25 this should beat trying to bend something from
> scratch.
> Chris Geils - Twin Cities
> 1978 26' Kingsley w/ very few mods; Headers, Progressive Dynamics 9040,
> aux trans cooler, one repaint in stock colors, R134a, Al rad, 50k mi
John,
"Worth the cost" is too subjective to be answered easily. I'll just say
I'm glad I converted to EFI and won't be going back. I also won't be going
back to EFI without the EBL upgrade. After installing EFI, I had an
apparently un-cureable off-idle stumble. Installing EBL immediately cured
that, as well as giving me complete control of the system and opening many
other options.
As for mileage gain, I don't claim to have seen any during the time I ran
in on a 455, and certainly not with my Cad500.
Recognize that I'm a perennial "tinkerer", with almost nothing, other than
the bare shell, original on my GMC. Unless you like tinkering with your
engine, & computers, I'd have to say "No, it's not worth the cost".
Americus, GA
​, etc.​
www.gmcwipersetc.com
On Fri, Sep 1, 2017 at 12:35 AM, John Phillips
wrote:
> Thank you, Ken
> Is changing to an EBL/EFI system worth the cost for an average user? Do you
> get a significant mileage gain?
Been following this thread and wholeheartedly agree with you, Ken.
Bob Price
John,
other options.
Americus, GA
​, etc.​
wrote:
> Thank you, Ken
you
