Traveling heat?
magnuson mike
49
Can the furnace be used while traveling? I am planning on taking a trip
south from Minnesota in Jan. or Feb. and am curious what others do for heat
in extreme cold. I have driven with the furnace lit and it appears to
tolerate the wind but I think it puts out the pilot when it shuts down. I
would guess that water in any tanks is not a good idea below freezing even
with the furnace on is that correct?
Thanks,
Mike
Are devices available to automatically shut the propane off in the case
of a gas line break?
Eric Tipton
etipton
Sent: Tuesday, November 16, 1999 2:07 PM
To: gmcmotorhome
Subject: RE: GMC: Traveling heat?
Mike,
"Technically" NO!
Now that that has been said, I travelled full time in my
GMC for 4 years and
over 150000 miles (1977-1981). A lot of that was in the
winter in northern
states.
When it was cold outside, I always ran my heater. I had
no trouble. My coach
was also a 77 with elec ignitor. This may be a plus
here.
We travel north 1-2 times each year now - after TN we
usually use the
furnace during travel if necessary. We now have a 78
with elec ignitors
also.
POTENTIAL PROBLEMS:
Check all your gas lines for leaks, or better yet get a
leak/pressure test
done. Camping World does it, I am sure other places do
too.
Biggest reason for NOT using furnace is in case of an
accident. You run the
risk of a ruptured line during a serious wreck. This
could
pose a major threat.
Remember - it's YOUR neck - drive safe.
3 1/2 cents worth
Mike
Furnaces optional in Florida
[mailto:owner-gmcmotorhome]On Behalf Of
Magnuson, Mike
Sent: Tuesday, November 16, 1999 8:10 AM
To: gmcmotorhome
Subject: GMC: Traveling heat?
on taking a trip
others do for heat
it appears to
it shuts down. I
below freezing even
Thanks,
Mike
Mike,
"Technically" NO!
Now that that has been said, I travelled full time in my GMC for 4 years and
over 150000 miles (1977-1981). A lot of that was in the winter in northern
states.
When it was cold outside, I always ran my heater. I had no trouble. My coach
was also a 77 with elec ignitor. This may be a plus here.
We travel north 1-2 times each year now - after TN we usually use the
furnace during travel if necessary. We now have a 78 with elec ignitors
also.
POTENTIAL PROBLEMS:
Check all your gas lines for leaks, or better yet get a leak/pressure test
done. Camping World does it, I am sure other places do too.
Biggest reason for NOT using furnace is in case of an accident. You run the
risk of a ruptured line during a serious wreck. This could
3 1/2 cents worth
Mike
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of Magnuson, Mike
To: gmcmotorhome
Thanks,
Mike
A while ago Gene and I put in a propane injection system that puts in a small
amount of propane into the engine that does a few things. First it allows a
higher octane to go in and helps when climbing hills, secondly, propane is
supposed to keep the carbon from building up in the engine, so a small amount
goes in all the time....but the most important part of the system has nothing
to do with the engine. It requires the installation of a special valve as the
first thing from the propane tank. It was developed for earthquakes and other
catastrophic events. In the event that propane goes through the line at a
higher pressure (i.e. if the line breaks) the valve cuts off all propane to the
coach. I find that this satisfies my safety concerns about leaving the propane
of when I travel.
> Mike,
> "Technically" NO!
> states.
> also.
> POTENTIAL PROBLEMS:
> 3 1/2 cents worth
> Mike
> From: owner-gmcmotorhome
> To: gmcmotorhome
> Thanks,
> Mike
Gene Fisher has the info on his web site. Below is the http so look at it
there. All I can say is from safety point of view, it is important.
al
http://www.california.com/~eagle/propane.html
> In a message dated 11/16/99 10:32:35 PM Central Standard Time, mr.c
> the
> propane
> of when I travel. >>
> OK, where do you get it? What does it cost?
