transmission
evan
8
3
i blew my transmission this weekend and would welcome any advice about getting it rebuilt and how to improve it
location? Transmissions are not light.
We have a rebuilder here in MN that has a good track record.
the questions is who is doing labor to remove and replace? and then you have the rebuilder. our MN guy does not remove or install transmissions,
just rebuilds them. It is all in the torqure converter, but he also installs forged parts rather then cast, and a few other items. Most important
thing is a big monster size transmission cooler.
Jon Roche
75 palm beach
St. Cloud, MN
Where are you located?
> I'm going to r and r it myself i heard some stuff on Manny's trans also
http://www.gmcrvparts.com
Missoula Mt.
Sent from my iPhone
> Jim Kanomata
> jimk
> 1-800-752-7502
Start with examining all vac hoses for soft or hard/ cracked lines. Not just the ones directly on the steel line.
We can ship you Manny's Trans with HD convertor
> Missoula Mt.
> Sent from my iPhone
> >> GMCnet mailing list
> > Jim Kanomata
> > jimk
> > 1-800-752-7502
What’s the cost and by heavy duty converter are talking lower stall rate ?
Sent from my iPhone
>> Missoula Mt.
>> Sent from my iPhone
>>>> GMCnet mailing list
>>> Jim Kanomata
>>> jimk
>>> 1-800-752-7502
>>> GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
The HD Torque convertors describe hoe the veins are all braised and the
bushing bearing is needle bearing. Since the veins are same as original, no
change in stall.
Lot of rebuilt transmission come with recycled convertors that are weak and
break down.
On our MH, they take a beating and need that extra.
> Sent from my iPhone
> >> On Mon, May 3, 2021 at 8:17 AM evan schroedel
> >> Missoula Mt.
> >> Sent from my iPhone
> >>>> On May 3, 2021, at 9:13 AM, Jim Kanomata
> also
> >>>> GMCnet mailing list
> >>> Jim Kanomata
> >>> jimk
> >>> 1-800-752-7502
> >>> GMCnet mailing list
> >> GMCnet mailing list
> > Jim Kanomata
> > jimk
> > 1-800-752-7502
Not hard to R&R, takes a bit of time. Make or acquire one of Ken Henderson's little fittings to lift and lower it, or run a strap around it. Helps
to drain it before you start, to keep the mess down. Flex plate bolts, cooler lines, vacuum line, electric connector, shift linkage loose and out she
comes. Loosen but don't remove the rear mount bolts so the mount can be tipped to let it clear. No need to remove the final drive, but loosening its
front mount sometimes helps, as does the front engine mount bolts. If the upper inner nut to the final drive is still there, it's a pain to get to. I
use a curved box wrench.
If you are close enough to take or send it to Manny, do so. Or likewise the guy mentioned above who they say gets good results. Or check with the
local shops for an old grayhaired tech who is familiar with the THM-425. Ask the tech to call Manny ans ask what changes from stock he makes for
longer life pulling a heavy load.
We sell only Manny trans as we know what goes into the rebuilt.
All others just drop in a standard kit.
Our Manny trans comes with the Allison style torque convertor with
braised fins and roller bearing and the clutch pack is of premium friction
plates and few other tricks to make it last lot longer than ANY in the
country.
On Sun, May 9, 2021 at 5:26 AM Johnny Bridges via Gmclist <
> it. Helps
> she
> its
> --johnny
> Braselton, Ga.
> in hell
