Transmission Update
gary j zingle
326
A coworker recommended Eldon Transmissions here in Edmonton as a good sho=
p
at trouble shoot and repair while not extracting the maximum money.
After an extended test drive with the mechanic today he found that, as I
reported earlier, the shifts were inconsistent.
Further it was found that what was actually causing the high revs when
starting the coach moving was that the coach was starting out in 2nd gear=
On a couple of occasions during the test drive it even started out in hig=
h
gear!
I was told that the vacumn modulator and the govenor were suspects.
Once up on the lift the mechanic found that at some time in the past the
vacumn modulator had been replaced with a poor quality part.
The govenor was found to be O.K. (The only change to the govenor was to
install a different spring to satisfy my request that low throttle shifts=
occur at lower speeds.)
The oil was not burn't, nor were there signs that the oil had been change=
d
to hide burn't oil during the motorhome sales process (grime undisturbed =
at
pan to transmission connection)
With only the modulator change, the govenor spring change, oil and filter=
change the transmission now consistently starts out in 1st gear and on
light throttle will upshift to 2nd at about 22 mph and to 3rd at about 30=
mph. Much more as I expected it should be.
The engine is not forced to spin the convertor up nearly as high and the
torque convertor has a much easier time of it.
I was pleasantly surprized to find that the modulator could cause so many=
symptoms. The modulator did not show any physical signs of total failure
(no transmission oil found in the vacumn line).
The transmission still shifts extremely softly so I still want to add the=
shift kit at some time in the future (although when I do so I think I wil=
l
leave the govenor spring as it is). At the time I install the shift kit I=
will change over to synthetic oil.
As explained to me today, apparently there are 4 types of modulators
available.
- - Low quality non-altitude compensating modulators (like the one previous=
ly
installed to my coach). The body is about 1 1/2 inches in diameter and th=
e
vacumn hose connects on the end. Apparently this modulator is calibrated =
to
sea level. (I think our altitude in Edmonton is just over 2000 feet) =
- - Higher quality non-altitude compensating modulators. I don't have any
information to help differenciate from the one listed above. Apparently
this modulator is also calibrated to sea level.
- - altitude compensating modulator. The body diameter is much larger (more=
like 2 1/2 inches in diameter) and the vacumn hose attaches to the side o=
f
the body rather than the end. Apparently the altitude compensator is take=
n
care of with an internal bellows. (This is the one now installed in my
coach)
- - non-altitude compensating modulator in a large diameter body. Apparentl=
y
the most obvious difference between this and the altitude compensating
module is that this one is lighter (no altitude compensating bellows
inside.
Although I don't have any part numbers I hope that the above may be of so=
me
assistance should someone else experience transmission problems.
Gary Zingle
1973 GMC 26 foot
Enjoying another sunny Alberta day
