Any time you are below the lock-up rpm of the torque converter, you will
have some heating of the fluid. The greater the torque load you have at
that time, (steep grades, trailer towing, etc) the more heating you will
have. That is why you manually downshift on steep grades. Keeping the
torque converter turning fast enough to "lock it up" prevents excessive
slippage, and reduces the torque load. Try to keep your transmission pan
fluid temperature below 200° farenheit, lower than that is better if you
can. In spite of what you have always believed, RPM's below the red line
when climbing hills are far better for both engine and transmissions than
staying in high gear and lugging the engine.
What is lugging? Anytime you can add more throttle when pulling hard
and not gain rpm's, you are lugging the engine.
Salem, Oregon
On Wed, Jan 22, 2020, 9:06 AM John Wright via Gmclist <
> I am with John and Russell on the transmission temps. Mine tpicall run at
> about 165F which is near the bottom of the temp gauge range. I had a
> torque converter failure that damage the transmission too. My gauge in the
> pan when to over 300F+. IMHPO if your transmission temperature is anywhere
> over 210F+ for extended periods then you need to look into the possible
> causes, granted if your climbing any grade it will increase with the
> extended load and you should downshift to S to get the motor speed up and
> not lug the engine or transmission. When I had the 77 coach with the 403
> and 3.55 gears I could climb most any grade and not have the speed fall of
> much below 50 mph.
> Regards,
> J.R. Wright
> GMC Great Laker
> GMCGL Tech Editor
> GMC Eastern States
> GMCMHI
> TZE Zone Restorations
> 78 Buskirk Custom 29.5' Stretch
> 75 Avion (Under going Frame up Restoration)
> On Wed, Jan 22, 2020 at 8:48 AM Russell Keith via Gmclist <
> > The THM 375/400/475/425 Troubleshooting Guide by GM states a normal
> > operating temperature of 170F.
http://www.bdub.net/manuals/THM_425_Trouble_Shooting.pdf
> > Other transmission related websites say an "Ideal" operating temperature
> > is 175F.
https://aljetsautomotive.com/transmission-fluid-flush-tips
https://mechanicbase.com/transmission/normal-operating-temperature-for-an-automatic-transmission/
> > If you look at the many transmission fluid temperature charts online,
> > you'll see that transmission life and transmission fluid life are greatly
> > reduced at temperatures sustained over 200F.
https://www.google.com/search?q=transmission+fluid+temperature+chart&sxsrf=ACYBGNQaUEqnina7kD2Cbe07foDyUHe9DQ:1579706774434&source=lnms&tbm=isch&sa=X&ved=2ahUKEwiFq46pwpfnAhWvmuAKHZZZDy0Q_AUoAnoECAsQBA&biw=2133&bih=1076
> > My transmission temp gauge usually stays between 150F and 180F; while my
> > coolant temperature gauge hovers around 190F (190 thermostat). I do not
> have
> > an auxiliary cooler.
> > The consensus is definitely "cooler is better" for transmission life. If
> > you can't keep it under 200F, then other measures should be taken to
> reduce
> > the temp, such as an auxiliary trans fluid cooler, or reduce the load,
> and
> > change the fluid more often.
> > Russell Keith,
> > 1978 E2 "Harry" 403 (still carbureted), Danny Dunn Tranny, Thorley, Stock
> > Brakes w/Remote Vacuum Brake Booster, Quad Bags, Dakota Digital Dash,
> 6.5 kW
> > Onan, Dunedin, Florida
