Evening all,
Recently replaced my tranny and didn't change to 3/8 lines, Has anyone with a temp gauge seen a major difference when they went to 3/8 from the stock
5/16. The PO of my coach took the lines off the radiator cooler and just ran through, what I think is suppose to be a good cooler, a tru-cool LPD
4590. I pulled the 3000# towd this weekend and the temp gauge which is on the return line got above 200 a few times in stop and go and slight hill
climbing, forgot to downshift at 40mph, forgot to turn on the aux fan. I'm running 3.7 gears with those big dodge rims and tires to match which bring
it down to the same as a 3.55 FD at the ground, according the RPM and speedo numbers. On the bright side the towd pulled real good. Any thoughts out
there.
Skip Hartline
there.
Skip Hartline
