Transmission Question -you may have just solved myproblem!
richard waters
1,236
Thanks for the response,
What you said to me makes sense. The reason I didn't install the
sensor in the oil line going to the radiator was because it seemed
like a lot more work, then just installing the sensor in the tranny case.
I was in a hurry (as is usually the case with me) and I didn't want to
mess with those oil lines.
Installing my new instrument panel sounded a lot easier to do then
it turned out! It looks great and seems to work great (except for
possibly the tranny oil temp).
Maybe after I install my new Statpower 40, PortaWattz 1000 Inverter
and generator transfer switch I'll redo the tranny oil sensor location.
Richard Waters '76PB, Troy, MI
> If you are getting readings than the gauge is working properly. the threads
> on the sensor bite thru the teflon tape if you put the correct number of
> turns on it.Take an ohmeter and tough the case of the sensor and ground and see.
> The problem you may be having is reading the temperature at the wrong place.
> You need to read the temperature when it just comes out of the tranny and
> before it goes to the cooler. On the hardest pulls you need to keep the temp
> below 200 degrees F.
