>Last month I mentioned in a similiar response that Chuck Stoddard
>advises
>not to use a gasket with the Ragusa pan, because it inhibits heat
>transfer
>from the transmission, but to use RTV as a sealant. That was
>subsequently
>questioned as possibly getting into the transmission fluid. I
>responded
>saying I would verify with Chuck at Myrtle Beach.
>I did ask him again during his seminar, saying that someone questioned
>the
>possibility of the RTV sealant getting into the transmission.
>He still recommends not using the gasket and says to carefully put
>RTV
>sealant on both the Ragusa pan flange as well as the mating surface on
>the
>transmission.
RTV worked for me.I installed my Ragusa pan 3 years ago and the only
problem I had was to get the oil off the transmission half of the
resevoir 'cause RTV doesn't stick well onless it is absolutely dry. So
that's what I did.
I will have to ask Sirums what they did when I had them change the oil
and filter last year???
David Lee Greenberg F22009
GMC Motorhome Registry
200 MacFarlane Drive PH4
Delray Beach, FL 33483-6829
>advises
>transfer
>subsequently
>responded
>the
>RTV
>the
>transmission.
that's what I did.
