Jim, I think he is referring to the round hole that is about 3" in diameter
that is in the torque converter housing on the passenger side of the bell
housing. Most all of them are missing from the transmissions that I have
seen. It is just a snap-in plate. I suspect that it's purpose was to keep
critters out. GM probably uses the hole for assembly or inspection
purposes, but that is a guess on my part. Manny might know for sure.
> If you want the cap I can get you a used one.
> On Fri, Dec 15, 2017 at 11:09 AM, Jim Kanomata
> > Best to replace with a vent fitting and run a hose to the outside of the
> > frame and put a clear plastic pop bottle so you can see it if it puckes
> up
> > fluid.
> > You can see the fitting on our sight under transmission, not proud of the
> > cost, but it is a discontinued part and we need to aquire it from a
> > collector.
> > On Fri, Dec 15, 2017 at 10:12 AM, James Hupy
> >> Why?
> >> Jim Hupy
> >> > Looking for a Transmission Peep hole cover. The round cover on the
> >> > passenger side of the transmission. Anyone got one?
> >> > Larry
> >> > 78 Royale w/500 Caddy
> >> > Menomonie, WI.
> >> > _______________________________________________
> >> > GMCnet mailing list
> >> > Unsubscribe or Change List Options:
> >> GMCnet mailing list
> > Jim Kanomata
> > Applied/GMC, Newark,CA
> > jimk
> > 1-800-752-7502
> Jim Kanomata
> jimk
> 1-800-752-7502
