I realize that our GMC's have with metal ( I assume steel ) lines from
tranny to radiator-tranny cooler.
I'm going to be installing an external tranny fluid filter and a new cooler
tomorrow and am trying to decide what to do re tranny lines.
Transmission cooler kits come with rubber ( tho be it hi temp rubber ) hose
to use. Rubber was also used to join metal to hose fitting at my last tranny
change/cooler install.
While steel has the obvious longevity, it can also be a pain.
I'm wondering if anyone has any rubber hose of length currently in use or
had in use and changed back to steel due to failure.
I'm not concerned about longevity as I would not have a problem to change it
out every few years, just concerned with drastic failures in less than 2
years or so.
Also... any thought on whether an external filter would increase back
pressure on the tranny itself in an undesirable manner? I know that the
catalogs tout "improvement and longer tranny life", but they sell this
stuff. I'm looking for some first hand exposure... pro or con.
TIA - Heinz
P.S. Still undecided on whether to use the termostat. It's fixed at 185
degrees +/- 10 degrees. Still looking for one that's adjustable.
years or so.
TIA - Heinz
