Transmission Leak
​Ken B.,
Thanks, I'll do that. Might even go ahead and do it before the next change
is due if it will cure the problem long term. (I won't tell him I've got
the external filter he doesn't like.) :-)
> Whoa, whoa, WHOA.
> I just re-read this thread to see what you are doing. When I installed my
> my Manny trans, Manny was standing right there in my hangar. When he saw I
> was using a Ragusa trans pan. Hw stopped me and said use NO GASKET. He
> handed me a tube of some kind of silicone that he liked and said to use it.
> I do not remember the brand but I never had a problem with it leaking.
> Get rid of the gasket and call Manny for the silicone type.
Ken H.,
Have you ever seen this photo:
http://www.gmcmhphotos.com/photos/transmission-filter/p57602-filter-2-cut-away.html
I think he's right; why put an extra filter in the loop when you have a paper filter already?
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Ken Henderson
Sent: Tuesday, November 28, 2017 8:38 AM
To: GMC Mail List
Subject: Re: [GMCnet] Transmission Leak
​Ken B.,
When I was fighting transmission leaks I got a gasket set from Manny, he included O-Rings that go on each bolt. Regarding gaskets, personally, I like
the cork gasket. If the pan is straight and the holes aren't dimpled, a cork gasket along with O-Rings on each bolt should work well.
