Transmission filters
hal stclair
923
Anyone know if the transmission filter issues have been resolved? There were a lot of them with undersized tubes (I ran into one) a couple of years
ago but I haven't seen much discussion of them lately. Need to do a transmission oil/filter change and wonder which filter to look for.
Any knowledge of the brands that will work?
Thanks for any guidance.
Hal
1977 Royale 101348,
1975 Eleganza II, 101230
1974 Eagle Bus 45',w/slideout
Last I heard, any are suspect. Buy locally so you can check it at the
counter, ir from a GMC vendor that will assure it will work.
Hal
1977 Royale 101348,
The Wix 58882 has always fit well.
Amazon.com http://amazon.com/ has it for under $19.00 free shipping.
> Hal
> 1977 Royale 101348,
Manny has the good ones.
455 F Block, G heads
San Jose
I replaced the filter with a WIX last year and it FAILED! 50 thousandths too small. Ordered an ATP and measured it - 5 thousandths too small. Put the
old one back in.
Emailed WIX but did not get a response.
Bill Van Vlack
November 2015; Since arrival: New HVAC blower, heat flap cable, headlight switch.
I ordered the Wix and will compare it to a Fram I have on hand when it arrives. I'd rather not remove the 'old' one until I have one in hand that will
hopefully fit. I think the Fram I have was one of the small tube ones but we'll see. Just hope the manufactures have corrected the defect.
Hal
1977 Royale 101348,
Bill,
What was the OD of the filter inlet tubes?
The Pedantic Mechanic
USAussie - Downunder
old one back in.
Bill
