Okay, I feel stupid having to ask this but I need some hand-holding, please. I cannot read the dipstick in my RV. I just finished dropping the tranny pan, replacing the filter and gasket and putting in new dexron fluid.
The service manual said 4 pints when changing fluid and that's what I initially tried. With 4 pints, it wouldn't go into gear. It might eventually go into gear but it wouldn't stay there.
I added a 5th pint and it would move but the front wheels wouldn't climb out of a small divot in the yard. After adding a 6th pint, it would go into gear and seemed to drive just fine.
So I drove it around the neighborhood, down the road a few miles and back, and then stopped to check the trans fluid while idling.
I cannot read the level on the dipstick. The fluid is too clean or maybe I'm too inexperienced with water cooled, automatic vehicles. I'm not sure why this is so hard. Thanks to how you fill the tranny, there is always fluid all the way up and down the stick. You wipe it off, put it in all the way, pull it out and read for the level. When I do this, I look at it straight on, turn it slightly so the light will reflect off the stick and fluid, and try to find a place where the fluid runs across the dipstick from left to right edges. I don't see it. I'm 6pts/3qts deep now and I don't see the level.
What am I doing wrong or not understanding about the process? I'm supposed to leave for a trip from FL to GA on Saturday morning, and this is making me worry.
Go ahead and assume that I don't know what you know. I won't take offense at the attempts to help me.
