Paul - are these hard stainless steel or are they the high tech rubber?
Eric Tipton
-----Original Message-----
Sent: Tuesday, September 22, 1998 6:10 AM
To: 'gmcmotorhome'
Subject: RE: GMC: GMC Motorhome Digest V2 #21
John:
Clarence Buskirk is an advocate of rerouting the transmission
fluid
lines along the frame, using Aeroquip lines and fittings, in
order to
elimanate the exhaust heat source.
Paul Bartz
To: gmcmotorhome
Sent: 9/22/98 2:03:12 AM
Subject: Re: GMC: GMC Motorhome Digest V2 #21
I have a Ragusa Transmission cover on order. Any recommendations
on
Trans
temp sensor and gage?
I just had Thorley headers installed. I find the oil cooler
hoses about
2-3"
from the headers on one side and transmission lines running
right under
the
header on the driver's side. At the moment, I plan to pick up
some
insulation (it looks like the split looms you use to cover wire
harness
with) from a local speed shop at $60 for a 15 ft
section...sigh. Any
suggestions? I don't see that a metal shield is feasible.
Eric Tipton
To: 'gmcmotorhome'
John:
fluid
order to
Paul Bartz
To: gmcmotorhome
on
Trans
hoses about
2-3"
right under
the
some
harness
section...sigh. Any
