> I still suggest that you pull the modulator and check to see if the trans is over (or under) full.
> It only takes removing one bolt and one push-on hose. It will take less than 5 minutes. Also look inside the disconnected hose for any evidence
> of trans fluid which would indicate a leaking modulator and trans fluid being sucked into the intake manifold.
That's is something I want to do. Just have to find a place to do it.
Question - If the modulator is passing oil to the manifold does it still operate correctly?
Steve Southworth
Palmyra WI
Steve Southworth
Palmyra WI
