Trans trouble on the road???? Tuesday update
steve southworth
3,088
Left Alamogordo this AM. Ran about 10 miles and checked and topped up trans. Ran 240 miles today. Lost NO trans fluid. Hopefully this will
continue for the rest of the trip. We just got off the road. I'll post later on what I think (guess) was causing the fluid loss.
Steve Southworth
Palmyra WI
Anxious to hear what's going on.
> Steve Southworth
> Palmyra WI
Ray Erspamer
78 Royale - "The Great Lakes Eagle"
Center Kitchen TZE368V101144
Wauwatosa, Wisconsin 53226
Email: 78GMCRoyale
414-484-9431
Web Site: http://ray-lisa.page.tl/
First I'll run down a few points. I did not do the modulator pull off level check. Could not find a place to do it where I could get under it and
where an ATF spill would be acceptable. Also this dip stick and fill tube has worked successfully for 3 years. I would have to jack the coach to get
at the trans vent hose. I ran it inside the trans crossmember and cannot reach it without jacking. I will change this when I get home so if this
happens in the future I will have specific evidence that the fluid loss is coming from the vent.
Modulator vac line is dry.
So do I know what is going on inside the trans when the fluid loss occurs. No. However I have reviewed how I operatied the coach and how the
driving before the days of the loss compared to those two days. Also how my driving today differed from the two loss days.
First I have not driven our GMC up any long severe grades since we've had it. Lots of long gentle hills and steep but short pulls. So I have no
"mountain" driving experience in the GMC. I also prefer to use the cruise control.
So on the grades encountered on Friday and Saturday the CC would go to full wide open. Then as the speed dropped off the trans would downshift. Then
I would remember that I'm supposed to be on top of this and use "super". This really puts an undesireable load on the engine and trans. I suspect
the ATF got agitated enough to foam and try to escape.
Today, besides picking a flatter escape route from Alamogordo, I very actively managed trans gear selection, throttle management and kept the engine
vacuum a few inches higher than on those two days.
If I have no further problems on the way home I will tend to believe I understand what happened. But note, I have not talked to Manny about this yet.
I want to get a few more days in before I call him.
Steve Southworth
Palmyra WI
Oh also I will continue to check the trans fluid level every 100 miles. We are also keeping track of how many times I put it in S and for how long.
Engine temps never go above normal. Today temps got as low as 31degrees and we drove in rain, sleet and snow.
The wind today was just nuts 30 gusting to 45. And of course never coming from a direction that would help. It's been that way this entire trip.
The copilot says with winds like we have experience in our travel this year that Phoenix next year is a no go for her or her GMCMH.
Steve Southworth
Palmyra WI
