trans park trouble.
Not the cable proper, but there is an adjustment on the side of the transmission
where the cable turns a bellcrank, which then attaches to the input lever on
the transmission. This rod is held by a screw, and can be loosened and moved
to adjust the linkage. I had this exact problem, and it appears to be due to
wear in the overall shift mechanism, but can be corrected via this adjustment.
- - Tim
> Hi All!
> Here's a interesting problem... sometimes, when i put the motorhome in
> park, it does not go all the way. it seems like everything is out of
> adjustment or something.sometimes, if i put it hard into park, it is ok.same
> with reverse, if i go past reverse, it will engage. do these cables have a
> adjustment?
> thanks!
> shawn
> www.geocities.com/MotorCity/Downs/9149/gmc1.html
Tim Dawson (tadawson) Owner/Engineer
TPC Services Bellnet: (972)-221-7385
Lewisville, Texas 75067 FAXnet: (972)-221-0393
"The world is complex. Sendmail.cf reflects this...."
Kewl idea
gene
>adjustment?
>Shawn,
>I also had this problem and fixed it last weekend, as Tim wrote the linkage
>is adjustable where the cable attaches to the trans. I found that my cable
>itself was dragging quite a bit, enough that combined with the free play in
>the linkage kept the cable from pulling/pushing the transmission completely
>into first gear or park! I used an old motorcycle trick (before the days of
>cable lubers) and tied a ziplock bag over the end of the cable at the
>steering column with rubber bands and filled the bag with the nets favorite's
>Mobil 1 5w-30. Let gravity do its thing overnight, and presto, smooth
>working cable. A careful adjustment in neutral and I now have a very smooth
>and safe parking gear.
>Jeff Kollmeier
>75 Glenbrook
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Shawn I had the same problem and it was suggested that I readjust the shift
linkage. It did the trick- thanks for the reply to me. I was glad that it
was not the parking paw.
Chuck Sankey
Palm Beach '76
Central Ohio
csankey1
To: "GMC Newsgroup"
Sent: Monday, July 24, 2000 4:42 PM
Subject: GMC: trans park trouble.
> Hi All!
ok.same
> adjustment?
> thanks!
> shawn
