Netters
Correct me if I am wrong but the transmission fluid Exits the transmission
through the *inside* line and Enters the radiator through the *bottom*
hole. The fluid then Exits the radiator through the *top* hole (and flows
through an auxiliary filter I added) and then through an external cooler
that I added) and Enters or returns to the transmission via the *outside*
trans hole.
A. Is this the correct route?
B. Is there a more effective location for my add-on filter and cooler?
C. I have a temp sensor in the trans pan and was going to put another in
a line at the trans...would it be better at the 'out' or the 'in' to watch
fluid temps
Thanks all.
Mike in NS
Michael Beaton
1977 Kingsley 26-11
1977 Eleganza II 26-3
Antigonish, NS
trans hole.
fluid temps
Thanks all.
Mike in NS
Michael Beaton
1977 Kingsley 26-11
Antigonish, NS
