- -----Original Message-----
To: gmcmotorhome
Date: Saturday, February 20, 1999 4:16 PM
Subject: Re: GMC: Trans Fluid Change again and more
>Mark......by removing the return line at the transmission and putting the
hose
>on the end of it, would you not also get the fluid out of the cooler.
>BTW.....any recommendations of external trans cooler?
>I drained the transmission today, cold, after the rig has sat for 2 weeks,
got
>a little over 8 quarts out by dropping the pan. I had read somewhere that
>draining cold gets some extra that will drain from the torque converter.
Will
>leave the pan off until tomorrow and then install the filter, and 8 quarts
of
>Mobil 1 + try to get the rest out via one of the methods described. Before
I
>do it, I have purchased a trans temp guage, and the instructions say to
drill
>a hole into the back of the pan, and insert a "bulkhead" piece, into which
>goes the thermocouple. Is this what y'all have done (before I drill the
>hole)??? Larry Nelson, PB75, Springfield, MO
Larry
If time and funds permit, you might consider one of the Ragusa aluminum
pans. They are pre-drilled for drain plug and thermocouple. It also has a
fins on the bottom for heat dissipation. I'm not sure on the capacity, but
it looks like it might even hold an extra quart or two. I have also
purchased his final drive cover and entry step; well crafted products.
Chuck
77K
To: gmcmotorhome
hose
got
Will
of
I
drill
Larry
Chuck
77K
