I got the installation about 2/3 of the way done. The wiring harness is fantastic and so easy to install. I took the “long” end and snaked it parallel to the battery cable from passenger side to drivers side, zip tying after I had the end in place. Attached the red + to the battery terminal on the isolator (?) and the neg to a known good ground. Attached the relays to the firewall. 1/3 done.And I'm very impressed with what came in the box. The wiring harness and relays seem to be top-drawer. The headlamps are excellent, too.
Like with so many things on the Motorhome - one thing leads to another. Now I want to refurbish the headlamp bezels. I just took a trip to the candy store (Ace Hardware) and bought some stainless screws to replace the rusty old ones. The clips are rusty too, but I'm too timid to try to remove them.
Drivers side headlamp bucket came out easily and with a common plier I bent out the inner part of the bucket a bit. Reattach the bucket, put the new lamp in, and the ring, bezel, attach new wiring - adding the included grease first. 2/3 done.
Removed passenger side headlamp - retainer ring fell apart. Tabs fell off and the ring came apart. Still - I had to test.
Grease in all connections and I turned on the headlights and they worked perfectly! Hi and low beams.
I can’t tell if they are any better than before in the daylight, though!!
I stopped by the auto parts store for a new ring and they didn’t stock it!? I remember these being on the Help! isle. Oh well. 2/3 of the way is good progress, and a simple, feel-good job.
